power steering
Douglas Mayer
08-27-2006 19:58:44
I do not have a manual for my F 40 but I was in Rural King and they had a manual that someone had removed the shrink wrap on and I took a look at it. The manual says that the power steering should take 1 qt and I have already added 5 qts and I can not see the fluid through the filler hole. How much does it require? The filter and reservoir is located by the distributor and the ram is in front of the radiator. Thanks doug
Tom Dold
08-28-2006 06:17:43
 Re: power steering in reply to Douglas Mayer, 08-27-2006 19:58:44
Douglas
It sounds like the front seal is blown out of the steering pump and the fluid is running into the engine crankcase. It should normally hold about a quart.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349 605-772-4541
[email protected]
Douglas Mayer
08-28-2006 15:16:21
 Re: power steering in reply to Tom Dold, 08-28-2006 06:17:43
Thank you very much. I will check it out. Doug
