soldering a radiator
Stuart brogden
08-27-2006 06:14:07
I need to do some soldering on a radiator , my question is , do you have to get the metal hot enough so that the solder will melt when it contacts the metal?
MikeJoel
08-27-2006 18:03:42
 Re: soldering a radiator in reply to Stuart brogden, 08-27-2006 06:14:07
Yes, the metal must be hot enough to melt the solder.
The flux helps draw the solder up into the little joints and such.
I didn't know about having to wash the flux off.
Mike
Gerald J.
08-27-2006 09:50:21
If you don't get the base metal hot enough to melt solder, you ain't soldering, you are blobbing and the solder will fall off faster than you can pick it up off the ground. That metal also has to be clean and you can't solder with water at that point in the radiator because it will boil and blow the solder out of the joint. Even with a BIG soldering iron or torch.
And you need a good acid flux that you must wash off or it will corrode the remaining metal.
Gerald J.
krue
08-27-2006 07:02:40
I think you do, otherwise the solder won't stick to it. But I could be wrong, most of the soldering I"ve done is electrical.
