oil pressure
Ken Miller
08-22-2006 12:51:21
My massey ferguson 235 when the engine gets warmed up the oil pressure drops from about 35 pounds to 0,could any body tell what the problem might be.the radiator started leaking about the same time,I took it out had it fixed.the oil pressure still drops.
Jerry/MT
08-23-2006 11:26:31
 Re: oil pressure in reply to Ken Miller, 08-22-2006 12:51:21
I assume you are using the correct oil in your engine and it's changed fairly regularly.
You may have a sticking relief valve in the lube oil circuit, a worn oil pump or your mains maybe worn. You could also have a leaking pickup tube. You'll have to open the pan up to check on the relief valve and the pickup tube. Sometimes you can clean up the relief valve and make it work properly. To check the oil pump, you have to pull it and make measurements.If you have a lot of hours on the engine, the mains maybe worn.
If it was me, i would pull the pan and check the relief valve first. I'd check the oil pickup tube and make sure that it was not leaking. I'm not that familiar with your specific engine but you might also want to check out any other potential oil leaks.
If that checked out OK, I'd pull the oil pump and have it checked or if the engine had high hours, I'd replace it. If the problem didn't go away, I check the mains with Plastigage and if required replace them.
Big Dean
08-22-2006 14:28:42
The First thing to do is check and see if you have diesel in th oil. It usually will not cause them to drop to zero but will cause the oil pressure to drop. If not that them it is probably the crankshaft bearings maybe the oil pump. Oh and check the gauge to sure sure it is ok.
Ken Miller
08-22-2006 16:20:49
 Re: oil pressure in reply to Big Dean , 08-22-2006 14:28:42
Is there way to check the oil pump easily without any special tools thanks Ken
