MF202 Z145 Governer parts and 3pt
D13
08-19-2006 06:43:29
My 202 has a Z145 Continental engine. The governer sticks just above idle, and then will jump to full throtle under heavy load. When the load is removed it will rev high until I use the foot pedal to pull it back down. I belive the ball and ramp system is jamming. Are parts available for this? I assume I have to remove the crnk pulley to get at the front cover, which in turn will require me to pull the loader pump shaft and the whole nose, which will require me to pull the loader itself, right? Is there a trick to getting the crank pulley out without pulling the nose?
Also, the 3pt leaks down quickly. Since this is not a live system (single stage clutch) this makes it virtually useless. Are the piston seals the most likely culprit and if not, how can I troubleshoot this?
