135 MF air filter
davids
08-17-2006 20:45:08
The Wix cataloge says the inner filter is #46297 and the outer is #42123. The filters are too short and the open end doesnt touch the bottom of the housing before the top end touches the top end. Its a 135 with the 3 cylinder Perkins GAS engine. Any help is appreicated. Thanks, davids
jerrycpp
08-20-2006 08:57:19
 Re: 135 MF air filter in reply to davids, 08-17-2006 20:45:08
You are correct that the "new" filters such as Wix are too short. My 135 with Perkins gas has the single element type. It had an old NAPA flter with a soft flexible lip on the bottom that sealed well. The "new" one had a hard rubber seal that was too short. I took a piece of Saran Wrap and some black silicone sealer and fixed it. I put the sealer on the hard rubber part and the Saran Wrap over that and installed it loosely. After the silicone set, I took off the Saran Wrap. It's been 160+ hours and it is working well.
mn.Chuck
08-18-2006 08:42:24
These are the correct filters for your 135 w/
Perkins gas. The very lst ones just used the
single element. The parts book shows a nut and
sealing washer down in the canister. It's been
too long since I've changed one but could that be
missing? Chuck
supergrumpy
08-18-2006 07:29:03
same tractor, my filter is single long bugger with spin kinda blades on the end, got it from AGCO, shake the wweds out every now/then
Ray,IN
08-18-2006 19:44:22
 Re: 135 MF air filter in reply to supergrumpy, 08-18-2006 07:29:03
I get both inner and outer air filters from a MF dealership in the next town. They are cheaper there than local auto parts stores.
