44 Hand clutch adjustment???
MillerJ
08-17-2006 19:30:05
Bought a 44 with hand clutch it does nothing when you pull it back. opened and looked inside looks like the pressure plate is moving??? is there an adjustment or is the clutch stuck???
Jeff
Harris Guy
08-18-2006 10:57:27
 Re: 44 Hand clutch adjustment??? in reply to MillerJ, 08-17-2006 19:30:05
We hit a grey area here. Two possible 'hand' clutches, one for PTO over-ride, other, usually on low profile 'standards'(30" rear wheels) that came without a foot clutch. If the PTO clutch, you
need to remove 2 or 3 snap rings, use 2 1/2" bolts, to pull the clutch pack. The 3 tapered springs may be broken, steel balls laying in the
lower housing. About a dozen tension springs, inside the pack. A speed shop can test tension pressure. Easiest to do your first by the MH book.
You may discover that someone drilled the assembly
bolted it up, to end slippage, labor, to rebuild.
If you are determined to restore a Live clutch,
I can copy the old MH manual, send it, don't put
this on my list, if you are not going to do more
than glance at the pages. The tapered springs were used later, on IH 400's, easy to get from
IH Dealer. Good luck.
millerj
08-18-2006 11:08:17
 Re: 44 Hand clutch adjustment??? in reply to Harris Guy, 08-18-2006 10:57:27
It has been Pinned to stop it from slipping.
I really do not need the hand clutch after all.
Thanks for Your help!!!!!
Jeff
