Perkins Injectors
JimG
07-30-2000 06:43:19
Hi! Does anyone know if a injector rebuild kit is available for my Massey MF150 w/ Perkins diesel? I have an injector leak, and it's ruining my new paint job! Seriously, it's time to get it fixed, and I want to make sure that all the o-rings and seals are available before I pull 'em off. Thanks!!!
Bob
07-30-2000 17:16:11
 Re: Perkins Injectors in reply to JimG, 07-30-2000 06:43:19
I dunno, you have to accurately calibrate the discharge pressure, and all in the engine should be fairly closely matched. I think they have to go to a shop that has all the tools to do it right!
DieselDoc
07-30-2000 18:45:37
 Re: Re: Perkins Injectors in reply to Bob, 07-30-2000 17:16:11
Where is the injector leaking, Top union where the injector line goes into the injector, or is it leaking at the split of the injector where the injector unscrews to open it up, either one may be loose enough to leak fuel may need tightend
JImG
07-31-2000 04:58:59
 Re: Re: Re: Perkins Injectors in reply to DieselDoc , 07-30-2000 18:45:37
Thanks!! I think it's leaking at the top. But I'm going to check it again. I think I can just replace the copper washer, if that's the case. Thanks for all your help!!
