Steering question for Big Dean
Used-to-be-Iowa-Dave
08-17-2006 07:08:09
Hey Dean,
I've got a 202 w/ the z134 engine that lost power steering. I thought it was the PS pump finally giving up after squeeling for a couple years, now I think it's just an o-ring seal in the steering column that leaked most of the fluid out. My question is, now that I have the dash apart and access to the steering column, is their anything else in there I should look at cleaning/replacing?
John Hopf
09-02-2006 12:09:36
 Re: Steering question for Big Dean in reply to Used-to-be-Iowa-Dave, 08-17-2006 07:08:09
I have the same problem with my 202 Work Bull same vintage. Replaced power steering lines that rusted out - then had power steerning in one direction only, then fluid started leaking from steering column, and tho power assist works both ways, I can't keep fluid in the system. I have searched for parts but can'r sem to find the seal that I would need to correct this leak. Please advise
Big Dean
08-17-2006 21:17:14
Hi Dave Is your MF202 a 1967 or later with full hydrostatic steering or is it an older one with the power assist steering with the drag links going from the steering gear to the axle?
08-21-2006 09:40:34
 Re: Steering question for Big Dean in reply to Big Dean, 08-17-2006 21:17:14
Older-'64 I think, with the drag links
