MF 165
JAT
08-16-2006 09:54:17
I just bought a MF 165 - where do I find the serial number on it? There are lots of numbers all over it but I'm assuming they are part numbers. Which one is the serial #?
-Also the 3point hitch doesn't work very well. It seems to go up all right but not very good going down. If the lever is all the way up I just nudge it down a little for the hitch to go down. If I push it too far down the 3point hitch won't move. I haven't tried it with anything attached yet.
-Also I need to replace the fan belt which would be easy except that the hydraulic pump is bolted to the crankshaft pulley. If I take out those bolts will the pump move foreward enough to get a belt in there?
Thanks.
Don-Wi
08-17-2006 23:09:16
 Re: MF 165 in reply to JAT, 08-16-2006 09:54:17
The drive shaft and the hub should be splined. Unbolt the pump, slide it forward the shaft will pull out of the hub.
The serial number is on a plate that should be on the dash down by the transmission, in front of the gear shift levers.
Can't help you with the 3pt, unless the 3pt response lever by your right heel (also where the dip stick is for the rear end) is on slow instead of fast. The fill point for the transmission is the cast plug w/ hex on it next to the gear shifts.
Donovan from Wisconsin
JAT
08-18-2006 12:33:34
 Re: MF 165 in reply to Don-Wi, 08-17-2006 23:09:16
Thanks
DavidP, South Wales
08-17-2006 04:59:22
As far as the speed of drop is concerned; have you checked the speed response lever situated by your right heel as you sit on the tractor? Move it to fast and things may improve if you have not already done so.
DavidP
