massy 180 wont start
Dave Sanders
08-15-2006 08:36:58
My 180 has been sitting since the 1st week of July when I finnished baling hay. The 3 weeks it sat it was HOT. I tried starting it this last weekend and it would crank but not start , i replaced the fuel filters and air bled the system but still no go. Any ideas , Im at a loss.
Big Dean
08-15-2006 09:21:56
 Re: massy 180 wont start in reply to Dave Sanders, 08-15-2006 08:36:58
Hi Dave Have you tried loosening one of the injector line compression nut about 3 rounds and cranking the engine over with the starter to see if you are getting fuel there it will sometimes take from 30 seconds to a minute for the injection pump head to load and start squirting fuel out there. If that does not do it go through the bleeding process 2 or 3 times including bleeding the fuel pump head by loosening the injector line and cranking the engine. If that does not get it started then the metering valve is probably stuck n the injection pump I have a picture that shows the prober way to bead the air from the fuel system if you would like to have it email me
