WVMark has the right info for you... But here's one more bit.. if you're not getting any engine braking going downhill, your Multi-power is in the "low" position. Engine braking is available in 'high' only. The speed difference between the high and low settings isn't wildly noticable... (about 15%) so your muli-power may indeed be working and you may not be noticing it.... especially if the tractor is new to you. This is a probably a good thing to know before you take things apart as it may define the scope of what you need to do inside the cases. To find out for sure, go find a hill with the multi-power lever it in one position, see if you get braking...then try the other position and see if you get any engine braking. Another way to tell is that the tractor is a lot harder to shift when at rest with any 'load' on the transmission at all. I've heard (but not read myself) that having a working multi-power is somewhat important as there are components of the transmission that don't get enough lube if you are stuck in the 'low' position..(i.e. you've got to run in high every so often to make sure oil gets to the right places). Hope this helps.. bbott
