MF 2135 Knocking
mlauk
08-14-2006 11:30:45
I have a MF2135 with a gas Z134 engine that smokes a little. I picked up a round bale of hay (1000 pounds) on the 3 point and a loud knocking sound started until I lowered the 3 point. Is the knocking from the engine or is it from the hydraulic area? It picked it up the bale no problem and I was just wondering if I"m due for a motor rebuild.
mlauk
08-14-2006 12:13:12
 Re: MF 2135 Knocking in reply to mlauk, 08-14-2006 11:30:45
Thanks for the info. I guess if I moved the position lever away from the constant pump position, the knocking would go away?
Big Dean
08-14-2006 11:54:41
That is the Hydraulic pump knocking that is very common on the Massey Ferguson tractor when lifting a heavy load or when you put them in constant pumping a lot of them did it when they were new. It will not hurt nothing.
