mf 35 trans question
popo
08-13-2006 19:23:13
got a mf35 with that pain multi-power. its leaking a little and i am going to fix it my self. my question is,
when i check the fluid after a couple of minutes of use the dip stick can't be read due to foam covering it. i dont remember it being like that before the leak started. is something else going on beside the multi-power leak from the weep hole?
the reason i ask if its something else i will just put in a reg 6 speed and get rid of the m/p.
thanks for the help
Aaron Ford
08-15-2006 04:51:05
 Re: mf 35 trans question in reply to popo, 08-13-2006 19:23:13
It sounds like you need to remove the inspection door (dipstick plate) start the tractor and find out what is going on with the oil. Perhaps there is a high pressure leak or a relief valve foaming the oil. The fact that it is foaming indicates that whatever is going on is above the oil level so it should be at least noticeable. Good Luck, Aaron
