tractor value
smcIN
08-12-2006 20:25:30
I have a question that I hope to get a answer here. I have found a 49 MH Pony and here is what I know so far. It had a broken piston and the owner replaced 1 piston and all the rings and all the bearings. He put it back together and It would not start. He said he thinks that the head needs the valves reground. He also said he has done some repainting on it but not a total repaint. He has the cycle bar mower that would go with it. He lost interest in it and it has sat for a couple of years. He said it was not stuck but will not run. What would you think would be a fair offer for it. Thanks in Advance Steve.
MF#1
08-13-2006 06:51:29
 Re: tractor value in reply to smcIN, 08-12-2006 20:25:30
I wouldn"t offer more than $500. Pistons don"t just break, normally. That crank could be in worse shape than you think/he thought. Can you do a valve job? If not, find out what that will cost. On the surface it sounds ok but it"s not running.
ps- It helps to include the model number in your subject line;-)
