Air cleaner elements for MF 1085
Dale Brown
08-12-2006 19:30:43
Hello, I need both elements for my MF 1085. I need the inner, and outer elements. I looked pretty good online as well as this site. I can't find them anywhere. Does anyone have any info on a source for these parts.I haven't tried a local dealer yet (it's the weekend), but I sure can't find any online.....HELP.....thanks. Dale
BigMarv1085
08-16-2006 07:41:45
 Re: Air cleaner elements for MF 1085 in reply to Dale Brown, 08-12-2006 19:30:43
Hey Dale, I ordered mine through TSC. I no that NAPA also carries them.
Don-Wi
08-13-2006 20:34:32
Your Massey dealer will have them, and possibly Napa or Automotive Supply may have them. If i remember right they're kinda expensive but still cheaper then a new engine. We replace ours every 5-10 years, depending on the hours and we blow them out in between.
Donovan from Wisconsin
Dale brown
08-14-2006 03:30:14
 Re: Air cleaner elements for MF 1085 in reply to Don-Wi, 08-13-2006 20:34:32
Thanks, I'll check the Napa store. Does yours have the red restrictor indicator?
Don-Wi
08-14-2006 08:57:49
 Re: Air cleaner elements for MF 1085 in reply to Dale brown, 08-14-2006 03:30:14
We actually have a 285, but it's the utility version of the same tractor, with the same engine and most parts are the same.
But with that said, it does have a red light in the dash, but I don't know if it works or not because I've never seen it come on. No restriction indicator that screws into the manifold though.
Dale Brown
08-14-2006 09:49:21
 Re: Air cleaner elements for MF 1085 in reply to Don-Wi, 08-14-2006 08:57:49
Thank You Donovan
