MF 50 Stuck in 2nd Gear--Help!!
Matt Roybal
08-12-2006 14:58:33
I tryed using Big Dean's tips, and the gears in the front move back and forth, as matter of fact I got it to go into reverse, but the fork that's towards the rear that needs to move forward will not budge. I tryed for a good while with the clutch pressed. Would removing the shifter stick itself help? I removed that pin on the shifter, but couldn't get it off either.
Lester Elwood
08-13-2006 05:09:10
 Re: MF 50 Stuck in 2nd Gear--Help!! in reply to Matt Roybal, 08-12-2006 14:58:33
Hi Matt Sorry about your shifter, been there. It sounds to me like the ball on the end of the shifting lever is out of the rail.Mine did that and the only way I could access it was to unbolt the gear box for the steering and lift it up.When this is done you can get to the shifting rail. Good luck Lester
