44 motor
mattlansing
08-11-2006 17:40:21
I found a 44 massey harris motor that was running 2 years ago. They would like $500 for it without manifold,carb, clutch and flywheel. No idea of the hours. I have a a couple motor that needs to be rebuild but the block is cracked. What should I do?? Tractor is going to be mainly used for show and some plow days. Let me know
matt lansing
cdmn
08-13-2006 17:41:47
 Re: 44 motor in reply to mattlansing, 08-11-2006 17:40:21
Fix the crack if it can be. If you want a show tractor, it's important to have corresponding engine and chassis numbers. Using an engine from a later or earlier unit wouldn't be as good. This doesn't mean the engine number and tractor number are the same. They aren't. Just that they were produced and put together that way at the factory.
