Freeze plugs
spitz
08-11-2006 11:12:48
How do you put these in?? They are the concave dish type. I know you are supposed to pound the dish to seal em up but how? Do I put anything behind them to help them seal??
Jerry/MT
08-11-2006 11:18:27
 Re: Freeze plugs in reply to spitz, 08-11-2006 11:12:48
Put some Permatex #2 on the core plug or some sort of sealer then get a piece of PVC pipe or steel pipe that fits into the concave end and drive them in.
spitz
08-11-2006 11:39:54
 Re: Freeze plugs in reply to Jerry/MT, 08-11-2006 11:18:27
do you drive them flat or concave in?
Eric in IL
08-11-2006 14:36:34
 Re: Freeze plugs in reply to spitz, 08-11-2006 11:39:54
third party image
I believe style "A" is driven in with the outer lip still being visible after installation. In other words the side that is down in the pic goes in first. It should be a fairly snug fit.
I believe style "B" should be able to be inserted into the hole by hand with the high side of the dome facing you. There has to be a step or ledge in the hole for this type plug. Afret inserting it in the hole, you strike the high center of the plug with a punch and hammer to make it "grow" at the outer edge, thus sealing it up. I put some type of silicone sealer on both type of plugs before installation.
Correct me if I"m wrong guys, but thats how I been doin it!
Jerry/MT
08-11-2006 21:28:11
 Re: Freeze plugs in reply to Eric in IL, 08-11-2006 14:36:34
Great pictures and an excellent description of how to do it! I have never seen the "B" type plugs before.
spitz
08-11-2006 21:33:44
 Re: Freeze plugs in reply to Jerry/MT, 08-11-2006 21:28:11
I have the type B in the pictures. Thanks for your help!!
