Massey 1130 hood side medallions
MF rules
08-09-2006 22:34:16
I'm looking for a set of good/near perfect 1130 hood medallions. They are round with 1130 stamped into them. Also looking for a new/near perfect front grille bar with the massey triple triangle logo for the same tractor. Thanks
mn.Chuck
08-10-2006 16:24:47
 Re: Massey 1130 hood side medallions in reply to MF rules, 08-09-2006 22:34:16
The round medallions are avail in Chilton,Wi, new
from a company called the Parts Depot. These are
MF originals 1-800-743-3768. A dealer (any imp.
dealer)can order for you. They do not have the
front bar. There is a change and diff. p/n in that
part. Changes at 9B 16711. Essentially, one has a
seperate triangle and the other is built in. Oh I
should have mentioned the p/n of medallions. 503669m2 Chuck
MF rules
08-11-2006 22:22:36
 Re: Massey 1130 hood side medallions in reply to mn.Chuck, 08-10-2006 16:24:47
Chuck, thanks for the info on medallions.....you mentioned the front bar has two versions..... are any of the two versions available yet?? Mine has the triangle built in but would settle for the other if its available???.....mine looks really bad!!!! Would the ones offered for 175, 165, 180 tractors work or are the hoods and nose cones narrower? Thanks again
mn.Chuck
08-10-2006 16:21:42
seperate triangle and the other is built in. Chuck
