Distributer
HaroldIHC
08-08-2006 21:53:46
Am restoring a W4, the engine is almost ready to start. It was stuck. I am replacing the mag with a dist. from a doner W4. I am not sure weather the system is pos or neg ground, also the coil terminals are marked + and - and a short wire runs to the dist. Is this corect? The old broken battery that was in the tractor was negative grounded. not sure about that. If these are corect then I should be on the right track. Can some one please enlighten me. Thank You. ----Harold
Bob
08-09-2006 03:34:13
 Re: Distributer in reply to HaroldIHC, 08-08-2006 21:53:46
The tractor would have originally been (+) ground.
If the battery has been connected (-) ground, and the generator was working, you can leave it that way.
Or, install the battery (+) ground, and polarize the generator BEFORE starting the engine the first time. (If it IS a generator, never having been converting to an alternator.)
Coil connections:
If battery is connected (-) ground, connect coil's (-) terminal to the distributor.
If battery is connected (+) ground, connect coil's (+) terminal to the distributor.
HaroldIHC
08-08-2006 21:59:30
Sorry, IM on the wrong board with this but maby someone on here ca n help me. Harold
