mf 240 axle slop
J.Collier
08-08-2006 16:36:10
my mf 240 axles seem to have more play then they should.my rear seals are starting to leak now causing the brakes not to hold. what is the best way to remedy this situation? thanks, jeff
DavidP, South Wales
08-10-2006 06:27:07
 Re: mf 240 axle slop in reply to J.Collier, 08-08-2006 16:36:10
Hi ,
Do you mean that you have end-float in the axle shafts? The easiest way to check this is to jack up and support both sides and see if you can 'pull' one of the wheels towards you. If you can then you should be able to push it back in and hear quite a deep 'bang'. Axle shaft end float is adjusted by removing or replacing shims which are mounted between the brake back plate and axle housing. Unless you cut the shims you will need to remove the shaft to change them. Seal wear is quite common and I would suggest that you change the seals whilst you have them removed. Changing the seals is another procedure which I would be happy to explain. If you only adjust the end float you should aim for clearance of 2 to 4 thousandths of an inch. The main thing is that the shafts do not butt and are tight. Make sure the hubs are tightened evenly before you check the clearance. Good Luck
DavidP
