mf35 carb rebuild
franklin co mo
08-08-2006 13:44:25
i need to rebuild my carb. gas turned bad (forgot to drain) and now it runs like crap and i have to keep the choke pulled about about 1/2 way or more to keep it running.
so my question is.... any tricks to the rebuild? things to watch out for?
thanks in advance for the info
Jerry/MT
08-08-2006 19:01:57
 Re: mf35 carb rebuild in reply to franklin co mo, 08-08-2006 13:44:25
Usually when choking is required to keep an engine running it's not due to the carb. A poor performing ignition system or an air leak downstream of the carb metering system can be the cause.
To check the ignition, pull the high tension lead out of the center of the distributor, hold it near a good ground, turn on the key and try a start. You should have a fat bluish spark. If you don't have that, that could be the reason why closing the choke part way makes the engine run.(It easier to ignite a richer mixture.) If you have a fat bluish sark, then make sure that there are no airleaks in the carb to intake manifold connect flange or at the intake manifold to head connection. Squirting a little starting fluid around these joints when the engine is running, followed by the engine speeding up in response will help you find the leaks. The other spot to check is the throttle shaft seals. If these aren't the problem then try adjusting the main jet per the owners manual. THEN, if all these things don't resolve the problem, consider rebuilding the carb.
franklin co mo
08-08-2006 20:54:14
 Re: mf35 carb rebuild in reply to Jerry/MT, 08-08-2006 19:01:57
jerry/mt
thanks, never thought about that. just got tunnel vision on the bad gas and thought carb.
thanks again
supergrumpy
08-08-2006 13:51:37
if the crud isn't too hard yet, try some Berrymans chemtool B-12 or whatever brand of solvent you like, sometiems saves a lot of work
