mhf202 1964 z134 gas engine lack of power
yves galarneau
08-08-2006 06:24:52
my engine run good but accelerate very slowly and lack of power
Jerry/MT
08-08-2006 13:05:53
 Re: mhf202 1964 z134 gas engine lack of power in reply to yves galarneau, 08-08-2006 06:24:52
Make sure that you have a good spark. Pull the center high tension wire from the distributor, hold it near a good ground and try a start. You should have a fat, bluish spark. If it's not a fat, bluish spark, check the points gap, the point resistance, the coil and the primary wiring(including the key switch) for high resistance.
If you have a fat bluishspark, check the initial ignition timing and the centrifugal advance mechanism to make sure it is working correctly.
If the ignition and timing check out OK, then check for proper fuel delivery to the carburetor and make sure that the carburetor main jet is adjusted properly.
Hope this helps.
