massey harris dont know what model
peter hendricks
08-08-2006 04:01:04
I just bought one but dont know what it is, it has 28" wheels, 4 cylinder 3-4 speed tranny, overhead valves, distributor on the top of the head, any help would be appreciated.
thanks Pete
Alberta Mike
08-08-2006 07:03:52
 Re: massey harris dont know what model in reply to peter hendrickson, 08-08-2006 04:01:04
Overhead valves with the distributor on top of the head? I think you meant "side valves" (flathead engine) right? Does the tractor have side panels (or the hinge remnants for side panels)?
Peter Hendrickson
08-08-2006 14:01:51
 Re: massey harris dont know what model in reply to Alberta Mike, 08-08-2006 07:03:52
flat head and yes remnants of side panels
Alberta Mike
08-08-2006 15:27:21
 Re: massey harris dont know what model in reply to Peter Hendrickson, 08-08-2006 14:01:51
Then you probably have a MH 101 or 102 Junior, or an 81/82/20/22 (same series). Obviously, the oval serial number plate is missing so scratch away and wire brush the upper surface area just behind and to the left (towards the clutch pedal) of the cast shifting platform (gearshift platform). The number will be hand stamped in there in large numbers. Look hard, they usually are not stamped in too deeply. Is the front frame a cast iron tub or is it a channel iron frame?
Peter Hendrickson
08-09-2006 04:19:09
 Re: massey harris dont know what model in reply to Alberta Mike, 08-08-2006 15:27:21
channel iron frame, 11 x 28 wheels
Alberta Mike
08-09-2006 05:31:13
 Re: massey harris dont know what model in reply to Peter Hendrickson, 08-09-2006 04:19:09
A channel iron frame with a 4-cylinder flathead and sidepanels would probably indicate a MH 81, 82, 20, or 22. These all looked pretty much the same. Did you find a serial number yet?
Alberta Mike
08-09-2006 14:29:01
 Re: massey harris dont know what model in reply to Alberta Mike, 08-09-2006 05:31:13
Well, there were small differences in engine size. I think the 81 and 82 came first (early 40's) and the 81's had the 124 cubic inch engine while the 82's had the 140 size. Later, the 20 and 22 showed up after the war I think with the 20 having the 124 and the 22 the 140. All engines were identical except for the cylinder bore diameter. The 81, 82, and 20 models had a slightly different shape on the side panel curve than the 22's. Other than that I think they were much the same tractor. Did you ever find a serial number?
Peter Hendrickson
08-09-2006 10:23:29
what is the difference?
Alberta Mike
08-09-2006 16:46:12
 Re: massey harris dont know what model in reply to Peter Hendrickson, 08-09-2006 10:23:29
See my last post above this one, somehow it ended up there.
