mf85 pto on all the time,then doesn't work ???
jjjginger
08-08-2006 03:13:38
mf85 start tractor and pto runs,conrol is in nuetral, [disengage with clutch all the way down],about five minutes and it stops and does it off and on with no warning.selector is in nuetral or eng. pto same thing, ground pto works, power steering is good, new fluid and filters
jeinsc
08-09-2006 13:14:25
 Re: mf85 pto on all the time,then doesn't work ??? in reply to jjjginger, 08-08-2006 03:13:38
Your MF85 may have a hydraulic clutch for pto. The power steering pump supplies pressure to clutch (pto). You will NEED a service manual,for this prob.LOL.Jerry
Aaron Ford
08-08-2006 20:40:25
I am going to base this off my 65, so it will be different. Here goes. The PTO surface of the clutch delivers power to the pump input shaft. on the back side of the pump there is a gear selector much like inside a manual tranny. This selector is set up to power the PTO shaft directly off the driveshaft of the tractor or off the pump shaft. The fact that it works in ground mode proves this half is okay. I would look into the gear selector behind the pump. Fluid drag can cause a PTO shaft to spin while in neutral, but it can be easily stopped. Good Luck Aaron
