275 Multi-power Help
krm
08-07-2006 14:29:04
I have a 1976 275 diesel that the multi-power is stuck in high range,any suggestions on a fix for this?Multi-power lever moves up and down buts does not effect ranges.
krm
08-08-2006 07:51:53
 Re: 275 Multi-power Help in reply to krm, 08-07-2006 14:29:04
I lubed shaft with wd40,it moves up and down but doesn't shift multi-power.
jogl
08-09-2006 03:28:59
 Re: 275 Multi-power Help in reply to krm, 08-08-2006 07:51:53
Try moving the clamp that attaches the linkage to the shaft sticking out of the bell housing / transmission. It is quite finicky so a small change could make the difference.
JP.
krm
08-09-2006 12:03:35
 Re: 275 Multi-power Help in reply to jogl, 08-09-2006 03:28:59
Does the shaft in the top of bellhousing supposed to come up until it tops out and does it go down until it bottoms out or is there a happy mediem in the middle?
jogl
08-09-2006 15:28:05
 Re: 275 Multi-power Help in reply to krm, 08-09-2006 12:03:35
I don't know, all that I do know is that after I changed the clutch on our 285 I monkeyed with it A LOT until I had it just right. I never did try pulling it all the way out or pushing it all the way in.
Let us know if you get it working.
Good luck,
JP.
jogl
08-08-2006 03:31:26
Have you tried lubing and adjusting the linkage that goes from the multi power selection lever to the little shaft that sticks out of the top of the tractor (either the bell housing or the gear case, I forget exactly how its put together without looking). I have noticed that those linkages are kind of light weight and can get bent and that they are kind of finicky to get set just right. To set there is some kind of set screw deal where the linkage attaches to the little shaft.
Good Luck,
JP.
