two injectors leaking badly
Matt Eve
08-04-2006 21:35:26
Hey Guys,
My MF 165 rebuild seems to have gone well - starts good and sounds good - but I have nasty leaks from under two injectors (one actually spits a little from under the dust seal like it's slightly under pressure.) I've replaced the copper washers but the leaks are no better. I've torqued them prety tight but I don't want to break off the studs. I even tried some copper head lacquer on one washer and it did no better. The banjo fittings on top and the steel injector lines all seal great - no problems there. Any ideas?
Many thanks.
