mf 35 petrol wont start
jackie walker
08-02-2006 16:24:19
i need help my starter motor will not crank over it seems to be jammed, all i get when key is turned is a click coming from the solanoid which i have had checked and is ok. i have attempted to take starter off but cant seem to undo it . I have been told there is 3 bolts but I can only find 2 I have tried manually with the crank handle while out of gear, also have tried to rock it loose in gear so far no luck .ANY SUGGESTIONS PLEASE
Jerry/MT
08-03-2006 10:50:42
 Re: mf 35 petrol wont start in reply to jackie walker, 08-02-2006 16:24:19
I think the click you are hearing is from the solenoid closing the starter motor circuit. If you hear a humming sound from the starter motor, then it's likely that the starter is jammed or has some bad brushes. If you don't hear the humming sound from the motor, I'd check the battery for charge and the battery connections for corrosion. Sometimes a simple cleaning of the battery connections is all that is needed. If the battery isn't charged, it's either incapable to taking a charge or the charging system isn't working. You have to find out what the root cause of your problem is and fix it.
coytee
08-02-2006 16:35:17
Not to be rude, but have you tried the obvious things like is battery fully charged, clean connections, ground ok, any corrosion in wire kinda stuff?
