hand throttle
in sticks
08-02-2006 03:50:17
have a 135 massey,gas.the hand throttle'' creeps'' down from full power.is there any adjustment to stop this from happening?
MF Poor
08-02-2006 06:29:44
 Re: hand throttle in reply to in sticks, 08-02-2006 03:50:17
Under the dash, you'll find a cork washer sandwiched between a couple metal washer, held in tension by a "spider" shaped spring/washer. That cork piece wears out. It's easily made new with a piece of cork gasket material. You can get a new one from Massey at a low cost also. There are 3 (???, maybe 2???) bolts and nuts that hold these parts together. They can be tightened somewhat to adjust the throttle "creep", but generally, once it's started moving, the cork is at the end of its lifespan. I recently replaced the cork, the friction discs, and the spider, all with new MF parts, for around $22, frieght included. Mine works like it did when new in 1971.
