3 pt lift problems
Tom671
08-01-2006 13:49:22
I just bought a MF 65 and have a problem with the 3 pt lift. When you lift the control lever to the raise position the lift arms go down and when you put the control lever down the lift arms go up and when you put the control lever all the way down the tractor stalls. Now I know why someone sold it. It has more problems than that. I am not famililar with MF tractors.
Thanks in advance for any help.
Tom671
smokey2
08-01-2006 14:46:57
 Re: 3 pt lift problems in reply to Tom671, 08-01-2006 13:49:22
Don't panic!!!!!
Look up Big Deans site and read the bit on Fergie hydraulics. Many replacement parts are available and most repaires have been covered at least once on this board. If you still cannot resolve it then an email to Big Dean will probably do it. Fergie hydraulics appear complicated but were designed and built in the 1950's and were way ahead of their time. They are absolutely brilliant when working correctly. A rough idea of what I do with a new/old tractor. Check the gear box oil and if in any doubt (ie water or history) replace it. Takes about 6 gallons so get the correct oil as it affects the hydraulic operation. When you have drained the oil to change also remove and clean the hydraulic filter.
