54 MH 44 Special shift pattern
Ian Johnsen
08-01-2006 00:00:37
My buddy recently purchased a 44 special which obviously has a 5 speed, but this tractor does not display the shift pattern like our other masseys. Some gears seem too close to tell the difference. Thanks
Harris Guy
08-01-2006 14:00:38
 Re: 54 MH 44 Special shift pattern in reply to Ian Johnsen, 08-01-2006 00:00:37
All 44 Specials have a gated shift bracket mounted over the shift boot. About 4 small bolts secure it. This pressed steel bracket has the gear
location raised a bit,and had a spot of yellow painthelping the new guys view the numbers/letter.
The pattern remained the same: 5R2 413
The Triples had a similar bracket.If this tractor does not have the gated bracket, or holes, showing someone removed it, the transmission case is not a 44 Special. This is a great tractor to
run, one of the five best to own.
Ken from Ontario
08-01-2006 16:50:39
 Re: 54 MH 44 Special shift pattern in reply to Harris Guy, 08-01-2006 14:00:38
Harris Guy is correct. Just verified on my
44 Special.
John17
08-01-2006 11:32:52
If I remember correctly the shift pattern is like this;2 R 4 on the top rail and 3 1 5. I may have R and 1st gear mixed up. I put a lot of hours on one of these machines, but that was a long time ago. Great tractor, good luck, JohnG
