MF 35 Perkins Diesel sleeve removal ????
woodache
07-31-2006 09:00:33
I need to rering my MF 35 Perkins Diesel, I have the new sleeve set to install. My question is how hard are the old sleeves to remove and do the new ones just slide in or do they have to be pressed?
Ricky in NC
08-02-2006 18:04:19
 Re: MF 35 Perkins Diesel sleeve removal ???? in reply to woodache, 07-31-2006 09:00:33
I took the block from my MF-35 Diesel to a machine shop. The machinest chizled out the old sleeves and slid new one's in by hand after cleaning the engine block. Later, I was turning the engine over by hand to set the timing gears , had not set the head yer, and one of the new sleeves slipped up aboutdthree inches. It was on an engine stand. I pushed it back in by hand. So be careful with the new sleeves. Engine is running great now. I used it today to rotary cut the woods around my house and drag out a tree blown down by the last storm...Execelent and strong engine.
DavidP, South Wales
08-02-2006 05:44:13
Hi, It is always advisable to press the sleeves out. However it is possible to use a very fine chisel but you must be VERY careful not to damage the block bore. It is essential that the bore is cleaned thoroughly. I use a rotary wire brush in a drill. The brush is a tight fit in the bore so it does a good even job. It is also essential that the recess at the to is spotless and remains so. Quite often with plenty of oil applied the sleeves can be pushed in by hand. If you need more push, some lengths of 7/16 UNF stud, a plate drilled to suit the block face holes and a small bottle jack will normally do the job. Make sure you set it all up square. Good luck.
Tractorsam
07-31-2006 10:59:37
I've recently done a 135 engine which I think is pretty similar. Those sleeves come in two varieties - prefinished and those requiring further boring. I had to use a press to extract my old sleeves and also used it to install the new ones although they went in fairly easily. If they drop in you've probably got problems. The biggest problem is the sleeves are only .040 thick and very prone to bending buckling so however you do it be carefull and ensure they are square. Also it seems to help if the groove at the top is absolutely spotless. Hope this helps, Tractorsam.
woodache
07-31-2006 13:10:01
 Re: MF 35 Perkins Diesel sleeve removal ???? in reply to Tractorsam, 07-31-2006 10:59:37
The sleeves I have are prefinished chrome. No boreing.
I think only the heads are different from A-152
