hydraulic fluid
mark sankey
07-28-2006 15:07:05
Just bought a massey 35 5 days ago. It is the first tractor I have ever owned. The question I have is the loader is real slow and I believe I need to add fluid to it but i have know clue as to wear to add it. Sorry to ask a stupid question. Also what fluid do you recommend? Thank You
butchtn
07-29-2006 05:02:43
 Re: hydraulic fluid in reply to mark sankey, 07-28-2006 15:07:05
if its operating slow its operating off of the internal pump in that case there is a filler plug next to the shifter and you check the fluid with the dipstick on the r side next to your hyd lift controls.i had to take the loader off of my 35 because the stearing system will not handle a load it cost me 500.oo to figure that out after replacing the steering wheel shaft two times.
old
07-28-2006 20:56:35
A lot depends on if it has a frout pupm or if it runs off the hyds already on the tractor. If its a frout pump then most use the loader frame for the fluid tank and you use the run of the mill hyd fluid in it. If it runs off the tractor hyds sorry I can't help
