MF 35 throttle problem
Mike R.
07-24-2000 16:12:06
I have a Massey 35 (1965). When I get off the running tractor to do something for a moment the engine often starts to rev up sharply on its own. The actual throttle lever doesn't seem to move much when this happens. However if it is under a load, for example if I have a bushhog connected to the PTO it is not a problem. Any ideas would be helpful. Thanks
Fred OH
07-28-2000 11:00:40
 Re: MF 35 throttle problem in reply to Mike R., 07-24-2000 16:12:06
Mike, you didn't say what engine you have but if it is a Continental, go up front and reach in through the fanbelt and behind the curved lever coming out of the governor and see if that vertical spring has any end play (up and down) and if it does, adjust till its gone (no play) Then if your throttle creeps, there is that cork washer thing on the throttle shaft (right under dash) that has a spring loaded thing to adjust to tighten up the throttle. It'll be obvious how to adjust it. If it won't adjust and stay where you put it, it probably needs a new cork washer.Try it and let me know how it does. I took my carburator off the other day and cleaned it and put it back on and now mines out of whack. Never bothered any adjustments,so they are pretty touchy.
L8R----Fred
JASON
07-24-2000 18:03:54
Check to see if your throttle linkage is not getting stuck or binded up. Or it could be something in the govenor.
