101JR throatle
James FFA presi
07-27-2006 08:12:43
the throatle on our 101JR is only used on the middle of the throatle control. what does it mean to be "twin power"?
thanks
james
Kevin Bismark
07-28-2006 17:08:38
 Re: 101JR throatle in reply to James FFA president , 07-27-2006 08:12:43
It was another leaver that changed the governor setting, you had the normal governor for normal stuff and a higher one for belt work
James FFA president
07-29-2006 04:02:13
 Re: 101JR throatle in reply to Kevin Bismark, 07-28-2006 17:08:38
ok, but i read some where that it would go a top speed of 16 mph. with the tracor going open all the way i go maybe 5 mph tops.
Alberta Mike
07-29-2006 04:49:23
 Re: 101JR throatle in reply to James FFA president , 07-29-2006 04:02:13
Open all the way and only 5 mph? Something is wrong there with your linkages or settings. Do you think the engine is operating at full RPM's and you're only getting 5 mph? Do you have 4th gear (road gear)?
James FFA president
07-30-2006 05:37:21
 Re: 101JR throatle in reply to Alberta Mike, 07-29-2006 04:49:23
yes it has the road gear but when the throatle is all the way open, the governer can still be moved even higher. The governer only opens up move when u are going up hill.
James FFA president
08-03-2006 11:33:13
 Re: 101JR throatle in reply to James FFA president , 07-30-2006 05:37:21
IS 4th gear always the road gear or is it like the farmall F-14 where u can change out one of the gears to a highspeed road gear.
