MF 135 Power steering pump seal replacement
John Burchett
07-24-2006 20:24:00
Trying to change the seal on the PS pump. (P/N 527904m91 (Barnes)) Seal doesn't want to come out. The seal looks different from the replacement part from the dealer; it appears to be smaller internally. The back side of the pump cover is yellow; does this mean that the pump was from an industrial tractor? The pump P/N is listed as the preferred pump for the MF135, but seems to have different internals. The pump is in pieces. I have torn the seal to pieces, but none of the metal part will come out. I have to do something. Advise please.
John Burchett
in Byng OK
Big Dean
07-24-2006 20:38:51
 Re: MF 135 Power steering pump seal replacement in reply to John Burchett, 07-24-2006 20:24:00
There are two pump that was used on the 3 cylinder Perkins engines the Barnes & the Cessna pump they will interchange and look the same on the outside but very much different inside and use different front seals. That may be what you have. If I can be of further help email me
