Loader Still Jumpy?????
Mike
07-23-2000 17:50:05
Well guys,Changed 1 HYD line to the lever block and tried to get the air out. Already changed all the HYD fluid. Didn't help. Thought should change Filter.. Boy that was an experence. Owner's manual said just under PTO cover..Sure after diconnecting 2- 1/8 inch Hyd lines and barley getting my hand in there I changed it..It was shot.. Put a new filter in---Still jumpy!!!!
But ALSO HEAR A TICKING NOISE from the HYD lines and see the HYD lines slightly jumping when just driving tractor..Once when lines wern't ticking the Loader whent up smooth... Loader works good and 3 point works good JUST IS JUMPY. Yes both are jumpy. Have ran both loader and 3 point up and down dozens of times to get rid of possable air.. Probley is the pump. BUT there is nothing I have found that it won't pick up. My Disc, if you don't watch what U are doing will lift the ftont wheels off the ground. If any 1 of U guys think it may be 1 of the Quick coupling's for the front loader--check balls in them??? 1 of U's told me about that happened to them.. But lost E-mail from them about how to check them without buying all 4 of them
Thanks Again Mike from Illinois
Jim Collard
08-28-2000 18:41:16
 Re: Loader Still Jumpy????? in reply to Mike, 07-23-2000 17:50:05
Hey check the lever on the right just under the seat .... If it aint in the right spot it will make it jump..... .hope I helped ..
