clutch not working all the time
gary ingram
07-23-2006 12:10:36
when i push the clutch in sometimes it wont let me shift r when i push in the cluth the tractor wont stop. but the cluth semes to be working it has pressure on it. buit sometimes it works just find in ever way.
thanks gary
Greg inKY
07-24-2006 06:27:20
 Re: clutch not working all the time in reply to gary ingram, 07-23-2006 12:10:36
I have a 135 diesel that does the same thing. It is sometimes dangerous in close quarters. Ain't gotta clue as to what the problem is.
Bob in Aust
07-24-2006 13:52:50
 Re: clutch not working all the time in reply to Greg inKY, 07-24-2006 06:27:20
I had the same problem with a FE35. The tractor was dangerous to use. I tried clutch adjustement with no sucess. I then put in an entire new clutch assembly (cost about $500 in Australia). The old assembly was very worn. the new clutch completly solved the problem.
Follow the instructions in MF 35 (and up) Tractor Assembly Notes by Jack Wetmore in the Articles under Research and Info on the left of this page.
Instructions in Big Dean's CD, or from a shop manual will also help.
It took me about 3 hours work to replace the clutch. It has worked perfectly ever since (about 5 years ago)
Jerry/MT
07-24-2006 13:46:05
Two possibilities: The clutch pedal freeplay needs adjusting or the pressure plate springs need adjustment.
All clutch pedals need to have a certain anmmouny of freeplay and there is an adjustment procedure for them.See the shop manual or the owners manual.
On the TO- series the pressure plate springs have to be adjusted to the correct length or the clutch will not release properly when you step on the clutch pedal. See the appropriate shop manual for instructions on how to adjust the spring length. You'll have to split the tractor.
