MH44 brakes special bolts?
Robin Mach
07-22-2006 14:20:10
Hi all,
Looking at the parts manual, the bolts that hold the brake cover to the transmission housing on my '52 44RC are listed as '3/8" x 1", NC, Hex - Special', part number 763 876 M1.
What's special about them? My 44 came with 6 bolts between both brakes, no two alike, so I need to replace them.
Thanks all,
Robin
msb
07-24-2006 20:22:47
 Re: MH44 brakes special bolts? in reply to Robin Mach, 07-22-2006 14:20:10
If its the bolts that bolt the drum to the differential shaft then I think it takes special hardened 12 point s.a.e. bolts.
Robin J Mach
07-24-2006 21:33:41
 Re: MH44 brakes special bolts? in reply to msb, 07-24-2006 20:22:47
Thanks much msb, but these are the bolts that hold the flat steel cover that the brake shoes are mounted on to the transmission housing. The only thing I can figure is that maybe they're some kind of shoulder bolt because you have to loosen these bolts and let the whole plate "float" when you're doing a major adjustment.
