What oil....
Daniel Coates
07-22-2000 13:30:49
i own a MF 35 1959 model, last of the 4 cylinders.
Now i need to change the oil in it, but what oil should i use, there are not a great amount of oil types to chooses from around here:>)
I know it is meant to be SAE 40 but, i can only get that by special order, and i want to change it today or tomorrow, so what do i put in it?
My local agricultural engineer, has:
20w30
15w40
10w40
20w50
so what should i use, i have 20w30 in it, from the last owner buti think it is wrong?
or what is the equivelent of SAE 40?
i live in the uk, and i can't be bothered to get SAE 40 dlivered, it's just to much hastle and expense, all of a sudden carriers don't like taking oil, because of spills etc..
any help is ppreciated..
Dan
[email protected]
Big Jim
07-28-2000 10:55:25
 Re: What oil.... in reply to Daniel Coates, 07-22-2000 13:30:49
I agree with the other posters. I have 3 diesel tractors and I run 15W-40 in all of them and have never had a problem. Any brand is OK as long as its API rated for diesel engines.
Greg Badeaux
07-26-2000 08:40:52
Dan,
I have a 59 TO35 4cyl Sandard. Ck the regestry.
I run Shell RotellaT 15/40 and have no problem.
Send me an email and we can discuss the TO35. I have done some reasearch and can let you know some other things about your 35.
Carl
07-23-2000 13:08:21
If it is a diesel have you checked about running the 15w40 oils such as Shell Rotella, Chevron Delo, Mobil Delvac etc. as these are what we use in the semi diesels some have went 100000 mile before overhaul. Also should be easily available.
george T
07-22-2000 23:52:18
if you cant get the right oil I usely put in a can of thick oil additive I use 20 W 50 and one can of additive it seem to work ok. the additive turns it to the next heaver grade but 20 W 50 is pretey thick already I onley use the additive when its going to be hot and hard work on the moter
michael
03-24-2001 15:22:49
 Re: Re: What oil.... in reply to george T, 07-22-2000 23:52:18
Dear friends: My motor oil will decrease when I drive over 1000 miles.What kinds of motor oil I can use?
My car:1992 SATUR SL 4DSD. Thanks a lot. michael
Dan Coates
07-22-2000 13:32:41
PS. It's a diesel engine..
bbott
07-23-2000 14:42:15
 Re: Re: What oil.... in reply to Dan Coates, 07-22-2000 13:32:41
I'd think that 15W-40 should work just for you just fine. I run it in all my diesels (4)... 2 of which date back to the 1960's...
The modern oils are lots better than anything that was around in the 50's and 60's... Whatever you get, make sure it's API diesel service rated.
Popular in US are...
Shell 'Rotella', Chevron Delo 400....
(I run the Delo 400)
bbott
