101sr problem
Luke Haefs
07-14-2006 16:54:30
I have a problem with the govenor on my 101 sr. If I move the throttle one or two notches from idle it will raise the rpm to about full throttle.
Dave_Id
07-14-2006 18:38:22
 Re: 101sr problem in reply to Luke Haefs, 07-14-2006 16:54:30
You'll have to remove the governor and take it apart. There is a pin there that is probably sheered, a common problem with the F226. I had two, and both were sheared.
Luke Haefs
07-15-2006 07:29:21
 Re: 101sr problem in reply to Dave_Id, 07-14-2006 18:38:22
Dave Is the governor in time with the motor? And were is the pin located?
Dave_Id
07-15-2006 15:13:21
 Re: 101sr problem in reply to Luke Haefs, 07-15-2006 07:29:21
No, it is not timed, and when you get it apart, you'll see the pin if it's sheared. Don't be hesitant to take it apart, it is probably one of the simplest governors I have ever seen.
Luke Haefs
07-16-2006 08:27:49
 Re: 101sr problem in reply to Dave_Id, 07-15-2006 15:13:21
Dave
There is nothing sheared off in the governor. But the rod that attaches to the carb. Hit�s the steering shaft before it engages the governor.
