Need quik help on 44 rpm adj
Kevin
07-14-2006 14:22:53
I am in knee deep with my 44 and need some help adjusting the rpm. I tried just about everything i could think of and cant seem to change it. It runs 1000rpm idle and 1650 wide open. I want it to run alittle slower on idle. Seems like no matter what i do to bring idle down it brings down the high idle too. Then i make a counter adjustment with the gov. screw to bring high idle up and low idle comes back with it. I have a pull tommorow and need some help. I even tried the idle screw on the carb and i didnt have much luck. Any help is apreciated. Thanks.
jerry l
07-14-2006 19:14:59
 Re: Need quik help on 44 rpm adj in reply to Kevin, 07-14-2006 14:22:53
Kevin- when you shorten the gov rod it opens the trottle up inside so if you lossen the linkage up where rod attaches to carb and turn it back down to your low idle and hold on to gov rod while doing this to keep engine from racing away let us know how you do on pull tommorrw
