7 foot brushog on 35 massey
george T
07-19-2000 21:56:03
I went to towen to day and on the way in I saw a feller brushhoging with a 35 massey and he was pulling a 7 foot john deer brush hog I couldent belive it he was realey makeing it move is the 35 capable of handeling it? I wanted to put a 7 footer on my 175 D but I dident know if it could handel it or not. anybody know. thanks george T
Bill
07-21-2000 20:18:29
 Re: 7 foot brushog on 35 massey in reply to george T , 07-19-2000 21:56:03
Some mower I've been looking at have an option of a xmission for under 50HP and for over 50.HP.
Phil in MS
07-21-2000 08:40:43
This must have been a pull type, as I wouldn't think the 35 could pick up a 3PTH John Deere safely!
bbott
07-20-2000 19:54:15
With something like a 35 there will be troubles steering and keeping the front end on the ground if you try and lift the mower with the 3 point.
As to your tractor (175) being powerful enough, I guess it depends on what you are cutting. For any reasonable activity, it should sail right through.
My 165 diesel SNORTS when cutting 10 year old bullrush clumps with a 6' hog. I have to raise and lower the mower carefully or it will jump around pretty good... even working on a single clump. Tough stuff.
Chip
07-20-2000 09:23:22
I think 7 foot is too much.
Dan
07-20-2000 06:35:20
I have a mf180 and it handles my 7ft bushog quite easily. Go for it. You can do it.
John Miller, III
07-20-2000 06:22:28
Manufacturer Rules of Thumb for Brush Hog/Rotary Cutters (1-2" brush/saplings):
4'- minimum 15 hp @ PTO
5'- minimum 25 hp @ PTO
6'- minimum 45 hp @ PTO
7'- minimum 60 hp @ PTO
Finishing mowers (grass) take a lot less hp. A friend just purchased a 15' Bat-wing and uses the Massey Ferguson 1165 (37 hp PTO)... and that mower weighs about 2600 lbs!
Since your MF175 is about 63 PTO hp, I don't think you'll have any problem using a 7' brush hog... except maybe going into tight area's... tough to fit! (Besides the bargain prices are on 6' and less)
I think the 7' on the MF35 was on the "abuse" side.
