model 20 ind. power steering trouble
smilie
07-09-2006 08:08:45
while running the tractor the other day, power steering went out like the flip of a switch after working properly for about an hour of running time. the tractor is a "71 with a barnes pump. the pump has an internal filter. could the filter be collapsed? or should i look elsewhere?
Big Dean
07-09-2006 08:36:20
 Re: model 20 ind. power steering trouble in reply to smilie, 07-09-2006 08:08:45
Did it start to work again after the oil cooled down? Did you check the fluid with the engine running? Those things will help to know where to start. It may have sheared the key on the drive gear I have run across that several times when one quit all at once.
