ferguson 35
heybusdriver
07-05-2006 12:58:07
What years were Ferguson 35 made? What are the features the tractor offers? I know were one is , don"t know price yet ,but have no knowledge of the tractor , all replies are appreciated, thanks Stan
Bill Brox
07-05-2006 16:30:51
 Re: ferguson 35 in reply to heybusdriver, 07-05-2006 12:58:07
Hi Stan, we need to find out what 35 it is first. The hydraulic lift capacity varies some.
Also horsepower.
It would also be nice to know if it is a US made 35 or a UK made 35. I would believe it a higher chance that it is a UK built tractor than if it was in the US, as Canada got more tractors from England than the US.
An early FE/MF 35 has 7/16" bolts that holds the axle housings in place. A later one will have 1/2" bolts. The early one lifts about 1500 lbs I think, and the later one about 2500 lbs on the lower link arms. To find out which one it is, look at the bolt size.
Some 35 had 2 stage clutch, which made it possible to raise and lower the implement without putting the transmission in neutral and lift up the clutch again. With the 1 stage clutch version you had to put it in neutral before raising the implement.
If it is a diesel, and of fairly early type it has about 37 hp, no matter 3 or 4 cyl. engines.
Later diesels had 42 or 44 hp, and then we are only talking about the 3 cyl. engine.
3 cyl. diesels have exhaust on the left side, 4 cyl. diesels have the exhaust on the right side.
The early Standard diesels, 4 cyl. was bad starters, the later ones too, except those exported to countries with cold climates who could order heater plugs in the combustion chambers and then it started like any normal engine. It is possible to put 12V Nissan heater plugs in, and you will not have any problem with starting anymore. If it is a Perkins 3 cyl. engine it starts easily. Depending on where around Vancouver you might consider a blockheater. The Perkins 3 cyl. is technically a misshap, a pre-combustion engine is not supposed to start without heaterplugs, but the Perkins engineers obvioulsy did not know that.
The weight of the tractor is about 1550 kg or so, 3400 lbs, that is the diesels.
A FE / MF 35 is often used with a 3 ton one axle trailer, with 1 ton on the rear axle and 2 tons on the trailer axle. This would be the weight it can easily carry.
The PTO has one speed only, 540 rpm, and it has engine and ground speed functions.
The tractor also has 6 speeds forward and 2 backwards, 3+1 high and low range.
The 35 was in the older days often used with half or full tracks in the forest. Tracks mostly used was from Canadian Bombardier.
Standard tires was 6x16 front, and 12.4x28 rear.
Hope it helps a bit.
Bill
woodache
07-05-2006 15:23:54
  Diesel Engine 4 cyl Re: ferguson 35 in reply to heybusdriver, 07-05-2006 12:58:07
Count the cylinders If it Diesel and has 4 cylinders say goodbye to it, unless it is so cheap that you cant refuse. Like a parts only tractor a few Hundred bucks. The 4 cylinder was the made by Standard engines and is the HARDEST Diesel ever made to start. Now if it Diesel or gas and has 3 cylinders this is the Perkins A-152 Diesel or G-152 Gas and in my opinion is the BEST Diesel engine ever made for this size. It runs and puts out power on tea spoons of fuel. And is very reliable starter. Even as low as -20* F below zero.
C. T. in Oklahoma
07-05-2006 13:46:15
Stan, good point, also, knowing if it is gas or diesel would help to provide horspower, and other info. I agree, although I don't farm, I run a brush hog, box blade, and have a boom for some lifting (a total waste of a nice tractor), everything I attempt seems to be trivial to my 35. Plus, as several folks on this forum have stated, the Perkins diesel sips fuel. I would love to work it and see how long it would run on ten gallons of diesel. C. T.
C. T.
C. T. in Oklahoma
07-05-2006 13:22:38
If you also mean Massey Ferguson, I have a 1964, Perkins 3 cylinder diesel that I paid $3,700 for and the Ferguson TO-35 was manufactured from 1955 to 1960, and the Massey Ferguson was manufactured from 1960 to 1964. AS far as features, the serial number will help us tell you. It could have a dual clutch, hi/low range for the transmission, three point hitch, et al. C. T.
heybusdriver
07-05-2006 13:37:06
 Re: ferguson 35 in reply to C. T. in Oklahoma, 07-05-2006 13:22:38
Thanks , I don"t know the serial number etc, the tractor is up near my property 170 miles away, This tractor has a front end loader on it, don"t know what kind, know it chained down to the drawbar, it is on a vacant piece of property with a reference address, looks like it has been used but not abused. Next time I go up there if it is still available will take a closer look, didn"t really get to see only a minute or less, but noticed it read Ferguson 35 on the hood.
Lou
07-05-2006 13:05:05
I have a TO 35 for sale in upstate NY. Made in 1960, for $3500. Gas rebuildt engine.
heybusdriver
07-05-2006 13:16:48
 Re: ferguson 35 in reply to Lou, 07-05-2006 13:05:05
thanks , I live in Vancouver (area) Canada, I was looking to find what features the tractor has, I don"t know anything about Ferguson 35, engine size, ,hydraulics, gears etc. Any informaition like this would be helpful , thanks Stan
GaryF
07-05-2006 13:32:19
 Re: ferguson 35 in reply to heybusdriver, 07-05-2006 13:16:48
Stan from the Wet Coast. It sounds like you are looking at a Ferguson 35 forrunner to the MF35. Pretty much the same machine just older. You could try a post over on the Harry Ferguson board on this website. They are an excellent and durable machine that was simply made and made to last.
