mf 175 diesel- positive or neg. ground?
mathyou
07-05-2006 12:09:47
Trying to help someone get this MF175 diesel tractor started- No battery in the tractor, they have a new 12v. battery and ive been told both ways are correct- My question, does this model have pos. or neg. ground? Can someone please help?
smokey2
07-05-2006 15:05:14
 Re: mf 175 diesel- positive or neg. ground? in reply to mathyou, 07-05-2006 12:09:47
Should be a negative ground. These tractors were built in the 1970s. MF kept using generators long after all cars were fitted with alternators so do not be surprised if was origionally fitted with a generator. Many early model MF tractors have been converted to use alterenators when the generator has died.
Big Dean
07-05-2006 14:50:10
All MF175 had a negative ground with a generator or an alternation it makes no difference
Jerry/MT
07-05-2006 12:32:12
If it has an alternator to charge the battery it will require a negative ground.
mathyou
07-06-2006 03:06:35
 Re: mf 175 diesel- positive or neg. ground? in reply to Jerry/MT, 07-05-2006 12:32:12
I looked and it has a generator. I also noticed that its a 'late' Mf 175 with the cast front wheel centers. I appreciate the help from all the responses.
mathyou
07-05-2006 13:47:00
i do body work, so I'm not a mechanic-Of course it seems like people dont know the difference with the number of mechanical jobs im asked to do. But this is my next question. The tractor is not at my house, so i cant look right this second if it has an alternator, but it seems to be a pretty big tractor. It has lights. I know you cant say with out looking, bit since the lights are headlight size, wouldnt it be more likely they would be run off of an alternator instead of the battery? To me, it seems like the headlights would drain the battery unless it had an alternator. I appreciate the response-thank you
Don-Wi
07-06-2006 09:40:23
 Re: mf 175 diesel- positive or neg. ground? in reply to mathyou, 07-05-2006 13:47:00
The size of headlights really doesn't mean anything. our 165 has 5 lights that run off the generator, and while they do discharge at slower speeds, when the engine is at working speeds the generator has plenty capacity. Othertimes, if the battery discarges some at night, the next time you run it during the day it'll catch up just fine.
Donovan from Wisconsin
