MF 35 gas questions
NCCub
07-04-2006 19:45:50
Recently purchased a MF 35 gas, 1963 model, it was vandalized, wiring messed up, gauges busted, been sitting for a while. Got it running this weekend, have a couple of questions:
The key switch has 4 "on" positions. I assume one for ignition, 1 for lights, what are the others?
The PTO lever. grinds when engaging, with clutch in or out, in gear or out, I feel sure the power is "live" but the grinding when engaging does not seem right.
Aaron Ford
07-09-2006 20:42:23
 Re: MF 35 gas questions in reply to NCCub, 07-04-2006 19:45:50
I looked at my MF65 '59 replacement switch and it had 4 distinct positions. It has off, on, on/lights and lights only. There might be a position for worklights but mine does not have this.
Good luck.
Aaron
Jerry/MT
07-05-2006 12:35:11
Your -35 has a live pto which means it has a two stage clutch. Maybe your pto clutch needs adjusting. You'll need a shop manual to tell you how to do this so if you don't have one, then get one.
Rod in Smiths Falls, ON,
07-05-2006 04:50:12
The simplest way to get the pto into gear without grinding is to shut off the engine, engage, then restart.
Alternatively, you may find it will pop in more easily if you rev up and drop down to idle quickly. A little grating shouldn't hurt anything. These machines are pretty tough.
