trans jumpin out of 1st gear
officejet
07-03-2006 20:38:34
I have a massey 44 that on a heavy pull it jumps out of 1st gear.I nee d help
jiskies
08-21-2006 18:55:15
 Re: trans jumpin out of 1st gear in reply to officejet, 07-03-2006 20:38:34
got a 255 which jumps out of 3rd!!! on a heavy load or down hill... not good but figured it was just part of it. Would like to know if there's an easy fix for it too?
TODD 24
07-04-2006 06:34:25
Don't think there's much that can be done; had the same problem on my 44 Special and always considered it a design defect. Usually popped out under heavy load like plowing. If there is a cheap fix, I'd like to know also.
officejet
07-04-2006 18:17:22
 Re: trans jumpin out of 1st gear in reply to TODD 24, 07-04-2006 06:34:25
Is this a hard repair?And what part do I need?
massey333
07-04-2006 10:13:47
You have a bad(worn)detent or ball in your shifter rail 0r the end(Ball) of your shifter lever is worn lopsided,Could be either or both,Massey had to change a bunch of Rails back in the 40s-50s due to THE SHALLOW DETENT OF THE FIRST GEAR.Since then we have only fixed one or two.
