Where is serial # on older MHF????
davidmf
06-30-2006 19:50:53
We just bought an old Massey Harris Ferg. tractor which need some tlc. However, need to know what year it is so we can begin to get some parts.
Here is a short discription of what I see:
- front and back rims look like the mid-50's Ford type
- the distributor is on center left side
- the oil filter, and cover, angle up on the right side
- there is only one filler hole for tranny, hydr., and rear axle fluid.
- the carb looks like the one on my Ford Jubilee
- while there are 3 forward shifts and one reverse, there is an extra lever which I assume is to shift in to high or low gears.
That' all I can up with. Hope someone can direct me in the right direction. Thank you in advance for you assistance.. Davidz
Big Dean
07-01-2006 07:55:31
 Re: Where is serial # on older MHF???? in reply to davidmf, 06-30-2006 19:50:53
The serial number is on a 2'' x 3'' metal tag some where on the dash depending which model it is where on the dash it is located. There is a lot of them the tag has been remove for one reason or the other. I have been told that http://montesequipment.com/ can tell you when the engine was made from the engine serial number that will get you close if your serial number tag is missing
davidmf
07-01-2006 09:27:12
 Big Dean, found tag in reply to Big Dean, 07-01-2006 07:55:31
Deanl, there is a tag on the dash and reads 183566, and I am assuming that is the serial number. Based on that and what I have seen on this site, it is a 1958 Massey. Right????
There is some other info. on the tag, once I clean it up and can see it better, what else should be on it??? Thanks for your kind response. David
phil(va)
07-02-2006 01:41:07
 Re: Big Dean, found tag in reply to davidmf, 07-01-2006 09:27:12
In front of the serial number you may have three letters like 'SGF' or 'SGM.' If so, probably you have a TO-35, and the third letter tells you whether you have the two stage clutch for live PTO or not. "M" would indicate the two stage clutch.
