Follow Up Pulley Troubles
TomTX
06-28-2006 15:32:02
My thanks to Don-Wi, Russ from MN, Kent, jones in texas, UncleTom, and Bill WI.
The pulley was wobbled out along with keyway. Had machine shop bore it all out, insert sleve, cut keyway. Machine shop drilled 2 holes where the two metals join, threaded them and screwed in 2 set screws, about 1/2 inch deep just to make sure it does not slip. He heated the pulley, froze the bushing, pressed in. Charged me $150; said $45 hour.
Now all I need is time/energy to put it and new water pump ($95) back together. Also bought 3 new belts, so total for this job will be about $300. Again thanks a lot for your good help. Tom
